Best upgrade for £300?
18 May 2011
Hello everyone.
I'm currently using a GTX 960, the 4GB card and fancied an upgrade.
Whats the best card to upgrade to for £300?
Thanks in advance :)
23 Apr 2010
West Sussex
Yeah it has to be Vega 56. I would avoid the RX 580 because it's like upgrading from your 960 to something like a 970/980 which IMO would not be a big enough jump.
9 Apr 2017
Eve Online
Do you overclock and enjoy tweaking a card? If so, Vega 56 has a lot of headroom. But if you just want to dial in a couple settings and run, I'd consider a 2060. OcUK have them for £330, and you get newer tech and gimmicks like RTX to mess around with, which may or may not provide mileage in the future (e.g. DLSS). The 2060 is generally slightly faster than the Vega 56 at stock/mild overclocking. If you check the Gamer's Nexus review (https://www.gamersnexus.net/hwrevie...-founders-edition-review-benchmark-vs-vega-56) the 2060 generally wins until the 56 is modded out. You do get a little more VRAM with the 56 though, and the £30 saved buys you a game.
29 Aug 2013
56
cheaper, more and faster vram, 3 games. same performance as 64/1080 once you bump the mem clock up a little and undervolt/turn power slider up which takes 5-10mins.
OcUK Staff
17 Oct 2002
OcUK HQ
OP
18 May 2011
As others have commented, the V56 deal is the best!
Sapphire Radeon RX VEGA 56 Pulse 8GB HBM2 PCI-Express Graphics Card (11276-02-40G) @ £299.99 inc VAT
11276-02-40G, Core Clock: 1208MHz, Boost Clock: 1512MHz, Memory: 8192MB 800MHz HBM2, Stream Processors: 3584, DirectX 12 Support, Vulkan Support, GCN, Freesync support, 2 Year Warranty.
Only £299.99 inc VAT.
ORDER NOW
Thank you Gibbo. I'll be ordering this tonight once I get back home.
One question if I may. I currently have a Corsair 500w PSU. Will that be enough for the 56? Or do you recommend I upgrade?
Many thanks :)
5 Jan 2014
56
Interesting you can do that and get more out but at the same time it would be nice if AMD released a card you did not have to "tune" to make it work like it should.
29 Aug 2013
I know, hopefully they dont bodge up Navi release. First impressions are very important on gpus, if all people hear is hot and loud on day 1 because of reference coolers they will think that forever
7 Aug 2009
London
As said above, vega 56 sapphire pulse. Using with an old 3570k at 4.5ghz and i know this will last me for at least 3 years , I only game at 1080p however. Runs cool and quiet.
17 Apr 2009
A Vega 56 and an overclocked i5 3570k on a 500W PSU? Could be pushing it, especially if you want to OC the Vega...
Permabanned
11 Jan 2019
bedlam
Depending on the games are setting, I would think the 3570k is getting its end of life.
I know it's overclocked but more and more games want cores instead of faster single cores. I don't see the 3570k lasting 3more years... Depending on the games you play
You could drop and i7 or exin in and extend its life a little..
