Calling upon the knowledge gods
ive had my 5930k for about 2-3 years (slighty overclocked) and the other day out of the blue upon booting it come up cpu over voltage to which I immediately shut down, booted the system up again and everything all ok. Then a few days later I started to download The Division 2 beta, while it was downloading I just left it to download, I came back to my pc to find the cpu running at 89 degrees :O (usually runs anywhere between 55-69 degrees while gaming). So again I shut the system down and 5mins later rebooted and everything was running fine again. Then on Saturday I was gaming and (temp was about 62 degrees) and then out of nowhere my pc just shut down. Tried rebooting but it wouldn't even boot and on my ASUS Rampage V Extreme it had error code 00 and red cpu led was on, on the motherboard. So I have tested the cpu in my fiances pc and same thing happened so confirmed its dead. My question is what has caused this? is it possible for the psu to surge voltage to the cpu? did the motherboard decide it wanted to ramp up of the voltage to the cpu? or is it a case of the cpu has just given up? Or will I never know the real reason it happened?
Reason I'm asking is because I don't want to get another cpu if the cause is related to the motherboard or psu? hope that all makes sense and sorry for the essay. Any help is very much appreciated.
Just to add I have Seasonic 1000w platinum psu so its a good psu
