- 21 Apr 2007
Add also the DLSS blurring and we have a fail?
Ooops no. Nvidia says it will take time for the AI to be trained to use DLSS effectively to remove the blur....![]()
Oh that's just plain ridiculous, so what are we saying here that DLSS will work better on your 2nd play through. Unadulterated pure spin and tosh from Nvidia.
The verdict is in the 2000 generation hardware features are a fail, you're paying way over the odds for something that doesn't really deliver and even if the tech eventually does come good it will done better on the next cycle of products.
The only possible reason to buy a 2080Ti RTX is if the 30% performance boost over 1080Ti is a must have no matter the cost.
