Sorry to hijack slightly but what would the minimum power supply you could get away with? Looking at the Vega 56 myself and have a 620w PSU, 4670k @ 4ghz .
Which model 620W PSU?
This oneWhich model 620W PSU?
Cool thanksI have the same processor @ 3.5, 2 HDD's, 1 SSD, 4 Case fans, card reader and DVD re-writer. All powered by a 650w PSU, calculator says I need close to 590W and everything runs fine for me.
So depending on what else you have in your rig, you *should* be ok, but wont have much room for overclocking it.
Why does age matter?Is an 8 year old PSU, my reply is <shrug> :/
Go big, you already have a barely enough watts PSU.
https://www.overclockers.co.uk/ante...plus-gold-modular-power-supply-ca-24p-an.html
I feel your pain though, I'm running my V64 off of a 550w PSU as well atm while waiting for the new one. Pretty much throttle it myself to ensure it gets enough juice.
I run a 550w 5 year old Corsair PSU, my Sapphire Vega56 Pulse happily sits at 1630-1640, at about 60 degrees. Fan at 1300rpm.
Are we sure its a PSU issue and not just a problem with the timings/voltages?
I found the power saving bios gave more stable underclocks than the default performance bios on my 64 nitro.Maybe it is just a bios and I need to try switch to secondary and then try to OC?
