It's a little bit blurry, this feeling inside, it's not one of those you can easily hide!
I don't have much money, as I bought a 2080 ti - I'd buy aaa mm dd if they weren't so *****
Way worse than FXAA and Nvidia felt it was ok to release this... Goes to show how low they think of the pc gaming community.
Happy to see them getting all this negative press. They got D.P. working overtime on here![]()
So if I got this right, basically you set ray tracing on in 4k, it automatically enables DLSS to down scale image quality but your so blown away by the reflections and lighting from ray tracing and the 60FPS on your 100hz monitor they thought no one would notice the down scaled blurred image quality
All look, you are posting more sources that back up exactly what I am saying. Thank you for proving my argument for me!
So game devs send nvidia the compiled executable that nvidia runs, and all done before release. Exactly as I said it operated.
It is almost as if I am entirely accurate and you were wrong
You're conflating game works and DLSS there,.although it's humourous you use an article that said Nvidia would rather do things in the drivers than have access to the source code to prove your point
The question is does nVdidia NEED access to source for DLSS to work, not do they already have it because of some gameworks feature. I've not seen anything suggesting they need it yet but regardless of that, this is just getting messy now. That last article said AMD prefer access to source more than Nvidia so I'm not sure what point you are trying to prove anymore.
Does Nvidia need the source? Sure, sometimes. Does it matter? **** No, it couldn't be any less important.
I'm not conflating anything, the point is access to source code isn't out of the ordinary and happens regularly especially in games with gimpworks, which all RTX titles have as well.
As for AMD etc. I never mentioned any of that, so I don't know who you're arguing with.
The point was simple - devs give source code to Nvidia (for DLSS & not only). D.P. thinks that's "misinformation". It isn't.
I feel massively let down by NVIDIA, i was a little bit salty about the RTX Implimentations but forcing RTX to use DLSS which means your performance is lower (for a minor RTX gain) but the textures are going to absolutely garbage.
I get about 90-100fps in BF V with RTX On (low and low items) with DLSS on at QHD Ultra. With RTX Off and no DLSS It's 120+ and looks vastly superior.
NVIDIA totally and utterly lied and mis-sold the RTX Series / DLSS. You can upscale with the game and get the same performance and vastly superior texture resolution.
Honestly, it looks soapy as hell, a bit like a 4K TV with all the garbage enabled by default, it was actually very trippy to play BFV with DLSS on, it looked like I was playing on low/medium.
"Super high quality sample" "this is 4k DLSS, that's just perfect", "could then in real time, enhance images" "this is infiltrater running on 1 gpu at 78fps at 4k at quality that's never been before"
Shame this isn't actually what consumers get.
So TLDR, You need to enable RTX to get DLSS (which is a big performance drop) you get far worse textures and image quality. It's better to upscale a lower resolution with RTX on and DLSS off for better performance and quality if you want RTX features, for those after frame rates, you wouldn't use either. They openly admit that DLSS isn't available for super high framerates because it will actually lower performance!!! Facepalm!
If you own a RTX 2080 Ti with a QHD Panel, you can't even use DLSS anyway.
Doesn't look too good to be honest and DLSS had such promise. I'm sure it will come good in the end, with AMD and Microsoft getting on board with machine learning aswell eventually, but for this first iteration from NVIDIA, things need to improve.
Things may still come good, but I'm not holding my hopes up. Another thing is lots of people here seem to be blaming NVIDIA for metro, but is it really totally their fault or should the developer take healthy part of the burden as well, after all they have released the game in this state?
Vega 7 is looking good, Least from these Linux results.
The test is done on a system with
https://www.reddit.com/r/Amd/comments/asdyon/radeon_vii_tensorflow_deep_learning_results_huge/
- AMD Vega FE*2
- AMD Radeon VII
- ubuntu 18.04 with kernel 4.18
- ROCm 2.1
- Tensorflow 1.12
Interested to see what the more consumer orientated RTX cards score as they also have (slightly knobbled) tensor units.Talking to the creator of the script, he kindly provided me with some numbers from V100, this is a quote:
Synthetic results ResNet50 V1.0. which is resnet50 in the benchmark code.
V100 FP16 892.76 (batch-size 256) 828.69 (batch-size 128)
With XLA turned on batch-size 256: 1452.96
I tried to run FP16, resnet50 with batch-size 256,
R7: 389 images/sec (batch-size 256), 382 images/sec (batch-size 128)
Vega FE: 178 images/sec (batch-size 256), 191 images/sec (batch-size 128)
Who does Nv actually pay to include RTX in metro, is it 4A, Deepsilver or both as the game devs surely can't get the blame as RTX inclusion would have came from above?
Do NVidia pay to have RTX included?
Is this a know fact or is it just unsubstantiated rumour?
I've had a quick look but as of yet found nothing to corroborate it either way.
Personally I don't think NVidia or AMD for that matter have that much say in the titles they put their name too, it is down to the developing studio, or maybe the parent company in the case of companies like EA.
Paying for game codes, or Dice helping AMD with Mantle are definitely things, that I agree would require some form of payment. But that in itself is a far cry from just saying that NVidia pay developers to include RTX.
Maybe they do, maybe they don't, I don't know.
I know one thing for certain, if Humbug was to make a full game out of the levels he was messing about with while toying with different physics systems and he decided to do it with ray tracing, there is now way in hell he could say to NVidia, "hey guys pay me to use your RTX stuff."
Anybody can write a game using Microsoft's DXR which works with NVidia RTX, so I'm not at all convinced that NVidia pay to include RTX. Maybe they did with launch titles, who knows.
