Ah, I have been looking at DD-WRT, is that different?![]()
I have no clue
https://dd-wrt.com/support/router-database/?model=WRT3200ACM_-
DD version
Its a business plan (installed at home), and yes its different hardware. Hitron router (which I clicked over to modem only mode straight away)
You can't use modem mode and Static IP address at the same time - its a known limitation over how Virgin provide the static service (via GRE tunnels).
You'll need either the multi static option (no additional cost for upto 5 addresses, your Hitron will take the first address and your own router any of the other four) or move to the Dynamic IP service for modem mode
I may try it when I have more time/am feeling brave.![]()
Coming to the end of my initial 12 month deal with £8 off for 200mb paying £38 p/m.
Quite happy with the service but has anyone had any luck with renegotiation after the first year?
Reliability and speed is really down to your area, I am in Earlsfield and on the 200mb and its solid. No problems at all.Currently with Sky Fibre Unlimited, and thinking of jumping ship to Virgin. Paying £27 monthly under contract currently. Has anyone made the switch? Is there any throttling with virgin? How is speed and stability? Would be great if it's a similar service, yet a few £ cheaper per month.
I'm on the Voom 3 Plus plan so have the same Hitron router. Does your static IP address still work correctly when you put it in modem mode? Also what router did you replace it with?
What's the best sub £100 router to use on virgin for increased WiFi performance?
Running ethernet around the house is a no go as everything is decorated and carpeted etc.A centrally located AP would be better if wifi is your priority, unless you have a specific reason to need a different router that you haven't mentioned?
My 2 living rooms I pre wired so have ethernet points in those 2rooms housing my server and pc.You can run flat Ethernet cables under the carpet along the edges of rooms, doesn't take long to do.
My wife can sit in the bedroom in the room above the current router with her laptop and have incredibly inconsistent WiFi. Was hoping a router better than the hub 3 would cure the issue .
That's the other option I've considered. Home plugs with an access point or 2 bottled around. Which access point did you go for?Had a similar issue with an upstairs bedroom, went through multiple routers trying to get a more stable signal, only solution I found was power plugs and then under carpet Ethernet with another wifi access point in that room. Might of been the aluminium foil wall insulation interfering...
