I'm running a Reolink set up. really happy with it
Maybe worth looking at the Ring floodlight cam? Doesnt cost the earth and saves you getting a full system if all you want is to protect the front of your house.* Sorry, not read through the thread *
so, at 01:00 today I had 4/5 hard bangs on the front door. I was up so maybe they saw the light on.
looked outside couldn't see anyone, went out, couldn't see anyone. ****** off so went out looking in the car, couldn't find anyone.
It's time for a CCTV system for the front.
My problem is, until 23:00/00:00 we've street lights, then they go off until 06:00.
Is cctv with night vision worth it? is the quality decent enough without costing a fortune? Or, would it be better to just get a decent quality without night vision and a motion sensor light
Positioning? Up high or a system fitted around/on the front door?
Rechargeable batteries in CCTV cameras seems a major hassle to me.I use the arlo pro cameras.
In that case that's pretty impressive and much better than I thought they would be. Might actually take a look at one then, as I would like to have one camera at the back of my property (my front/side cams are hard wired) but there is no easy internal route for wiring at all to the back.Well they been up there a month and are only down to 50% so not bad. You can buy the cables to hardwire them if you really want too. Mine are reachable from upstairs windows so easily removable and chargable
Does anyone have any experience with Synology Surveillance Station?
No but I seem to remember there being some sort of emulator or hosted demo solution for you to try before committing to buying the Synology with it's own OS.
Quick google gives this
https://demo.synology.com/en-uk/surveillance
Me, this is how I run my cameras and it works perfect. Already had the NAS so when I decided to get cctv installed it was a no brainer to use the surveillance station.Does anyone have any experience with Synology Surveillance Station?
