Man of Honour
- 8 Nov 2007
- Outer Space
@fastboy HDR aside, how do you rate the monitor otherwise, colours, refresh, blurring etc...?
Thanks
Thanks
Excellent thanks for the info, think I'll give it a miss then, sounds very similar to my last screen, I'm eyeing up the Alienware 25" 240Hz with G-Sync, but it's fairly expensivehi
well they seem ok,bearing mind I came from 3 60hz monitors 240hz is night and day.
there is a bit of ghosting if you shake windows about but im happy..now I also did have one of the EG 27' 1440p 144hz monitors for a while as a stop gap and I don't recall seeing any ghosting on those.
I find turning the blackboost and MRPT off seems better..would I buy them again,probably not as there is definitely some colour changes around coloured web pages when dragging
yes I have those I believe, as I said I can run 240hz no problem but I will double check.
the ones ive tried are
cable 1: 2m DisplayPort cable supports video resolutions up to 4Kx2K and transmits HD audio and video from computer to display. Compliant to version 1.4 specifications; works with DP, DP++, DisplayPort++
cable 2: 8K DisplayPort (DP to DP) cable - 3m - (32.4 Gbit/s, UHD resolution with 8K/60 Hz or 4 K/120 Hz, supports HBR3, DSC 1.2, HDR 10
I also tried the stock cable that came with the monitors with same results.
its no biggie I guess but would have been nice to have it working.
are there any ocuk sell that you know will work?
im not now,it was just someone mentioned HDR and though I would give it a try since the monitor supports it (which it does and works over hdmi perfect)
and why is that? HDR 400 looks great on my monitor. There is no way I would want to get blasted by 1000 nits at the distance I'm sitting at. Even HDR 400 can get a bit uncomfortable at low ambient lighting.Well I would say "perfect" would be a bit of an exaggeration. Anyway yes just saying you would be better off not using HDR on that monitor (or any monitor that is not 1000 or 600 at worst).
