*** The Official OCUK Cinebench R20 benchmark Thread ***
24 Feb 2003
Stourport-On-Severn
Here you go.
So basically, there's nothing between them.
30 Jan 2012
Stoke On Trent
Just updated my BIOS (not the one for 'new upcoming cpu's' though, im not that brave :D ) i was a couple behind anyway :)
@moorhen2 You have same RAM as me in my sig? 8-Pack Dark Pro 3200Mhz?
Timings look similar.
I didnt bother doing a best out of three.
9 Mar 2015
Earth
7980XE
All core speed: 4.8 GHz
Single core speed: 5.0 GHz (will run at 5 Ghz when only up to 2 cores in use)
Multithreaded @ 4.8 Ghz - 10712
Singlethread @ 5.0Ghz - 516
24 Feb 2003
Stourport-On-Severn
Scoreboard updated.
Big score Radox-0 nice :)
Possibly a bit late for this thread now. But i really think it should be a basic requirement to run both MT and SC to be on the scoreboard. After all, we are supposed to be able to compare like for like and speed for speed. Not much point if peeps don't post both at the same time.
Caporegime
OP
17 Mar 2012
ARC-L1, Stanton System
Scoreboard updated
Thanks for the input, i think its fine, out of 26 so for 25 also posted ST, most do that without it being a requirement. :)
9 Mar 2015
Earth
5.2 Ghz on my 8700k rig. Not sure why my All core score seems low compared to other's yet ST is about right. May try a few more runs later or something.
