- 22 Nov 2018
16 gb or 32gb? Which ryzen are you using currently?
3466 at cl16 is very good in a ryzen system. I would be interested if someone runs 3600+ in a actual ryzen sys and/or with 32gb.
I red that 32gb are not possible with higher frequencys (3200+) dual rank is also much faster than single rank. This means 2x16 GB should be much faster than 4x 8gb. Unfortunately, patriot has only 16gb kits with 2x8gb, but I want 32gb :/
Dual channel has more bandwidth than single channel but each channel will have 2 slots. So 2x8Gb is one channel and 2x8Gb is the other channel. It's the same as having 2x16Gb.
