alcohol?
Hmm...Not actually tried. I'll give it a shot.
alcohol?
Need a good tar remover. Winter use has covered it and stands out on white
Looks incredible.Gave mine a much-needed clean at the weekend and also (hand)polished with SRP then followed up with EGP.
Paintwork is in a pretty poor state, but now we've moved and I finally have a garage and driveway again rather than parking on main road and public car parks I can get it sorted. Otherwise, from a distance, it looks very nice indeed when shiny!
It's an Individual colour called Tanzanite Blue. Very dark blue, almost looks black in some lights but really pops in the bright sun.Looks incredible.
Is that Azurite or Carbon Black? (or just something else)
My F10 is Azurite and I've got to be honest I have no idea when I see another on the road if it's carbon or azurite.
First time using snow foam yesterday (Auto Finesse Avalanche). Really impressed! I just washed it off after as I only wanted to get the main dirt off, I gave the car a proper clean the other day but with the weather as it is, it didn't stay clean for long. I was surprised how much it removed. Granted when the car dried there was still a general layer of lighter dirt, but the main stuff was removed.
Has anyone used Gyeon View yet? I was a bit underwhelmed with the Caramics glass kit, and the reviews and videos of View look amazing. And it looks pretty easy to apply.
I've got gyeon synchro on my m135i and gyeon view on the glass. both been on about 12 months now and working great still![]()
Just ordered the Q2 View kit, hopefully going to try it out Friday. Any tips for applying? I've read that the final Repel layer can be a bugger to buff off.
no it was straight forward to be fair. I did the polish bit and then just coat the screen until the bottle runs out and then buff off. just don't rush. It does say windscreen for the full bottle but I applied a coat to all the windows with the majority of the bottle being used on the screen.
Personally think AF products are usually overpriced crap, but hey.Looking for some advice please guys for a few bits on my car, preferably stuff I can get from Halfords!
Firstly getting rid of all the black spots on the roof:
Anything specific I can buy to get rid of the green tree/plant crap and also anything to refresh the rubber weather strips(?), if thats what they're called:
Same thing with the rubber and plastic around the door handles, anything I can do to freshen them up and get them back to looking more like new?
Cheers!
You'd be after a Tar remover for your roof, an APC and a brush for the other parts.
I like AutoSmart Tardis and G101. However, I'd recommend for ease, BiltHamber Korrosol and Surfex HD.
In comparison
Korrosol = £6.48 per 500ml
AF oblitarate = £8.95 per 500ml
I personally think that BH products are a lot more 'potent' ie you need less to get the same effect.
Yep, I'd rather buy direct from the guys who make the stuff, i.e the actual chemists.Agreed on autofinesse overpriced and no better or even worse than cheaper stuff from less "scene" brands.
our windows are the same size and I did them allCheers! I think I read somewhere in Gyeon's literature a bottle should coat the windscreen and two side windows.
