Any starting tips that you guys playing early can reccomend?
I did the same and played for a good hour or so. Had no issues at all with crashes or glitches, maybe this is because I'm running my pc at stock everything so no pc on cpu or gpu either.Used the VPN trick last night and played for about 3 hours. It must just be me as the game ran very well, no crashes and I did not notice any bugs. The turret worked fine.
I told you last night the Scott's are on the bottom of AMD liststill nothing....going to go round to the houses where the amd machines i built are...rip out the cpu's and gpu's....and send them back to amd in a big huff....
G
wow if you think the nerf was bad on the turret in the open beta, in the final game its really bad. It literally lasts 2-3 seconds before lost.
I assume there has to be a way to power it up else its useless.
Ton of bugs that werent in the beta.
I think the turrent issue is now a bug, basically if you deploy it even if not attacked it will 90% of time just despawn, can see the counter start to move down slowly then it just goes poof, it seems to happen if its idle, so you get the enemies aggro'd first so it shoots right away you get some use out of it, but the moment it stops shooting it will probably despawn.
Picking up items as junk doesnt mark them as junk.
I had an elite enemy just despawn. He wasnt dead.
Game is a buggy mess, private beta to open beta to final game gradual worsening of the game.
I told you last night the Scott's are on the bottom of AMD list![]()
that would be ME i got 2700x on lunch day and picked up Key to play division as an actual AMD user...Oh dear that doesn't sound good! Thing is with these promotions they're normally advertised as "whilst stocks last", and going by some of the promotions from OCUK about buying the AMD cards and getting free games to sell on, sounds like it wasn't quite a guarantee! You're going to end up with some pretty miffed people if they've purchased a key of someone else and that can no longer be fulfilled due to running out of keys.
That is really bad, they know when the keys they have run out so remove the promotion. People are swayed towards hardware with game giveaways as it helps with cost vs buying hardware and a new game. Not good at all if these are true.
