Is 144hz worth the upgrade?
21 Mar 2012
Really happy with my 27 inch 144hz 1440p screen, 144hz really does make a difference in games, no way I could go to a low hz now for main monitor
15 Sep 2006
Liverpool
I think it's all psychological, you want to believe 144Hz is better, your body will trick you to cause that desired effect. Companies also want you to believe so you shell out extra for the Hz.
This is so blatantly false. I'm so confident I could pass an a/b/x test with 60hz vs 144hz that I'd bet my house on it.
You probably forgot to set your Windows to 120hz in display properties.
24 Aug 2013
Lincolnshire
For me 60-144hz is massive. I could tell it’s at 144hz with nothing more than a single mouse movement.
I remember going from 1080p then to 4k thinking wow this is really quite nice. Then I went to 1440p 144hz more as a test and nearly feinted.
In bf4 I was just in pure awe of how good it looked, ultra smooth. Even today I prefer high refresh over everything.
Sure there gets to a point where say 165hz to 200hz is very very minimal but 60-120/144 is huge.
22 Nov 2006
It is false, switch a 120hz monitor down to 60hz and you can INSTANTLY see the difference. Even on the desktop. Input delay increases and everything feels less smooth.
18 Oct 2002
Manchester
Find it really difficult to go back to 60hz now, it seems so jittery even browsing. The only regret going 144hz is I didn't upgrade my GPU, my 970 really really struggles on some games at 2560X1440, thankfully a lot of games I play are strategy, but would be nice to have a 2080ti for the few modern games I play.
1 Jun 2014
I've never owned a monitor that ran at less than 100Hz. Went from high end CRT to a 120Hz TN in 2011, and have been enduring it ever since. I wanted to upgrade a few years ago, but I thought I could wait it out until OLED/Micro Led became common place. Oh young Random Guy, you were so naive. The fact that a lot of nicely specced monitors seemed to have QC issues was also a deterrent. Anyway, I can't imagine going to a lower refresh rate now.
19 May 2012
I'm so tempted to go 144hz. Its just the cost associated and the fact if I'm going to do it, I might as well throw the extra £200-300 and go ultrawide too.. and then I need to buy a new PC.
24 Feb 2013
East Midlands
I wouldn't bother, just stick to 2560*1440. You ideally need a 2080ti for anything more with the latest games and the eye candy on as well as high hz. Just look at metro exodus as an example. Playing on uw at 60-70 fps defeats the purpose of having a high hz monitor.
19 May 2012
I'm on a 4k TV at the moment (2080/8086k).
So the monitor route does look attractive eventually.
OP
5 Jun 2007
extremes.spacious.indelible
I run a Sapphire Vega 64 and can play elite dangerous, PUBG etc on high/ultra and get between 120-200fps
Caporegime
28 Oct 2003
Chestershire
It’s going to be interesting when the next gen consoles come along with a better Zen CPU. If developers max it out with games at 4K30, will it actually make it harder to run PC ports at 60/120/144Hz without some sort of compromise in resolution or graphics settings. Or am I spouting rubbish? :p
