- 1 Jun 2012
- Hereford
IIRC the LEDs are controlled by the sapphire trixx software? You need to decide whether you want the bios flashed or not. However a little homework is needed to see if the pulse 56 can be flashed to a v64. One bios, switch position is protected. The other one will allow you to flash. I'd use overdriventool for the overclocking and undervolting btwCouple of quick questions if someone could help me out. Looking to undervolt my 56 pulse soon, should I flash the bios to 64 first or not bother?
Also, anyone know if you can change the colour/behaviour of the pulse LED on the side?
Cheers!
