yep, totally missed that post (i'm playing wii golf on an emulator with my son - it's god-awful - and decided to answer your post in between shots. Bad idea.)Well there is no issues it's perfectly working, just the part about upgrading to Zen 2 and better GPU one day
Nvidia geforce aorus 1080ti oc 11gb
GSkills Trident 16gb rgb 3200mhz
250gb ssd m.2 samsung evo 960
1tb wester digital 7400 rpm black edition
Amd ryzen 5 1600- 6 core 3.2ghz
Asus rog strix x-370-f motherboard with rgb and Aurora
750 w be quiet gold power supply
The case is full glass on both sides and it has 3 integrated fans.
For gaming the 1600 will have no problems that you would be able to compare with relatively, personally, (i.e. direct comparison to 1700) - it will cope with anything that's thrown at it.What if he let it go for 1000, will this ryzen 1600 he struggling, what's a it comparable to Intel wise
and will that motherboard suffer with Zen 2?
Yes, you would still benefit from the higher speeds of zen 2 - the speed and clocking ability is more about the CPU but a superior motherboard will obviously help get the most out of it - but the key is the CPU itself.That and support for Zen 2 even if there is a hit it's still going to be higher performance?
You're saving ~£500 (and warranty) when directly compared to a new Ryzen build - but the margins of performance loss are far far less when compared to that of the INTEL build you were considering (but had dubious issues) and a far greater saving.I think I may be making a good choice and saving 750 quid.
Of course, although you may have a stock fan on top of the 1600 which should hold a 3700 clock but the fan may get noisy. So, you may want to factor in a decent third party cooler:Is it worth me overclocking the 1600?, might try the ram too.
Claims on the warranty during the primary warranty period (primary warranty period varies by region) must be processed through the seller of the product, who will forward the defective product to ZOTAC for warranty services. Warranty claims during the extended warranty period must be filed directly with ZOTAC. Extended warranty claims must be emailed to ZOTAC at [email protected] and please provide the following information:
- name of ZOTAC product
- serial number of product
- customer’s name
- date of registration
- photocopied purchase receipt and registration certificate
- description of the defect
- system specifications and operating system.
Warranty claims during the extended warranty period must be filed by the original purchaser of the ZOTAC product who has duly registered for product warranty services online in accordance with paragraph 3 above.
Product returned for extended warranty services must be sent to ZOTAC or to a service center designated by ZOTAC as per ZOTAC’s instructions. You will be responsible for costs and risk of transportation.
I doubt you'll be disappointed with the 1080Ti - and there is a certain amount of 'anticipation' stress owning a 2080 ti at the moment which could have taken some of the enjoyment away from a second hand unit with limited/constricted warranty.Well I think a GTX 1080 Ti will last me a few years, its a shame about the rtx problems if there wasn't any out of the ordinary could have easily switched it over to one.
With the right cooler, certainly no harm in trying - but don't be disheartened if you can only hit ~3.9Ghz. Is the memory running stable at 3200MHz (very possible given brand)?16gb ram and if I can get a 1600 to near as 4GHz as possible?
Should be a good rig I think
I'll post a picture when I get it
He actually running the memory at 2133 apparently didn't boot at rated 3200
And without sounding like a downer - you may not have solved it. You won't no for sure that it's held until the system has rebooted a few times.Also I fixed it and set it to 3200MHz, had a go at changing the timings but didn't boot so so stock at 3200MHz.
Yes, that's all reading correctly. What i meant is that you won't know for sure if the system will hold the memory at this speed until the system has cold booted a few times.Seems to have CPU Z and HWInfo report 1600 which will be 3200 so. Should be OK?
