LG 34GK950G, 3440x1440, G-Sync, 120Hz
28 Mar 2019
I am getting "The OnScreen Control update can be applied to one monitor only. Disconnect the connected monitor and try again." message after I didnt have the USB cable connected the first time. Any suggestions on how I can install the firmware without getting this message? Thanks.
28 Mar 2019
Daniel at LG can you help me install firmware for 34gk950f? I keep getting "The OnScreen Control update can be applied to one monitor only. Disconnect the connected monitor and try again." message after trying multiple things.
Man of Honour
12 Jan 2003
UK
Have you got a second screen connected to your graphics card? Make sure you have only the LG connected preferably by DisplayPort and the usb cable also connected. Try a different USB port from the pc perhaps too and make sure to give it time to install itself before you attempt the firmware update
27 Mar 2019
Possibly a laptop? Things getting mixed up with internal screen maybe. Changing primary display may help if that is the case.
Another here giddy at the thought of his F being on it's way v.soon :)
Hope you get your firmware sorted.
13 Jan 2018
London
On my primary PC I kept seeing that message if I connected the DP and USB. With only the DP cable it would fail after that step. Connecting both the DP and USB to my secondary PC worked immediately. No idea what the cause was. Both have the same version of drivers and Windows but one has a 1080Ti on a Z370 chipset versus 1060 on an older one (worked on latter).
Try another PC or laptop if you have the option.
26 Sep 2018
Hey everybody!
Since stock starts to emerge again i was curious which model to get. Then i stumbled across the sweclockers review of the g and f model. They came to the conclusion that the g-version is better, because of less motion blur and less ghosting https://www.sweclockers.com/test/26...ync-eller-g-sync-lika-men-anda-inte/4#content (and other reasons i dont care much about tbh or that have been fixed since). Then i started looking at the tftcentral review again and noticed that the f-version was in 17 out of 25 transitions too slow for a 144hz monitor, while the response times of the g-version are only in 5 transitions too slow. Unfortunately there is no ufo-test comparison at tftcentral which i could've additionaly looked at. Which leads me to my quesion to you folks, did anyone of you own both models and can confirm that motion blur and ghosting between these two is pretty similar in actual gameplay? Would hate to spend an additional 250€ if there is no meaningful difference.
Motion blur comparison: https://cdn.sweclockers.com/artikel...2MGQxZWY2ZDVjYzNmM2E1ODRlNTE4MTFjMTFiMjI5NSJ9
22 Feb 2019
Guernsey
I did connect with USB cable and still get message
I assume you have the USB connected and you have the latest LG software installed?
https://www.lg.com/uk/support/support-product/lg-34GK950F
19 May 2012
Can anyone take some photos of their monitors at their desk? Is 34'' enough? I'm not sure if 38'' is still where its at?
BTW every jealous of owners of this monitor.
Caporegime
18 Oct 2002
I've had both (the 38UC99 also) and I must admit the 38in is definitely next level with its size and 3840x1600 resolution...
This F is pretty ****ing epic tbh, but the upcoming LG 38in may just be the only monitor on the horizon that will one-up it. I'd wait (if you can). And get saving, I expect it to be £1600+ at least.
19 May 2012
Thanks. Any links for that monitor? I'm definitely interested..
