How do you move an auto when the battery has died (im assuming with no power the gearbox is stuck in 'P'?
A recovery vehicle would just use a booster pack as with more power it allows selection of neutral.
I’ll say it - Bloody Italian electronics!![]()
Depends on the gearbox tbh, on some automatics (usually older ones) lack of electrical power makes no difference,in the case of an electronically controlled/operated ‘box then you’d - in most cases - just get power to the vehicle via either a jump start or charger.
As above.
After 24hr on charge, the car barely started, but it is absolutely fine.
Requesting Ferrari courier me a new battery up so I can fit myself as I want to use the car and don't want to risk it not starting anywhere other than home where I don't have such easy access to an electrical charge point.
