My Uuni arrived yesterday, hopefully give it a run out at the weekend
That could mean too much yeast or too warm.Cheers, got some dough on
Recipes said it would rise by about double, mine's taking the house over![]()
dough too elastic what do I adjust, usually make it in the bread maker following the recipe and have been struggling with it stretching back, its put in the fridge after a couple of hours and being knocked back and left in there for a day or two before using, so just discovered this section of the forums so thought to ask on here before I make a fresh batch ?
Thanks
Yeast 1/2tsp
300g Strong White Flour
1tbsp Olive Oil
1tsp Salt
170ml Water
I would say be more forceful with it , when forming base, you're using fingers not a rolling pin. ?dough too elastic what do I adjust, usually make it in the bread maker following the recipe and have been struggling with it stretching back
how did you form the base, too ? the irregular base makes it look non-digital.2nd one had nduja on, oven wasn't hot enough on that one though
bring it up to room temperature from fridge before handling ... mine'll take 2hours for that.
dough should also be tacky, so that you can't can't fully handle it without some semolina/cornmeal on the board+hands...
... I usually open bread machine an hour into 2:20 programme and add fluid if needed, after poking it.
interesting research paper on why sourdough addition = digestibility
Phytate Degradation during Breadmaking: The Influence of Flour Type and Breadmaking Procedures
look good, i have had some mixed results but have defiantly found 24 hour proof is lots better. Also if cooking on gas, get a good 450 degrees at the back. drop the pizza in and kill the gas to the lowest and keep in for up to 3 mins, jut makes the bottom a bit nicer
have thermometer on order to check temps
