Bykski block arrived in England this morning, waiting to clear customs! Yay
Well I ordered mine 10 mins after you looks like mine is still in China
Are you sure? Seems strange that it wouldn't be holding hands with our onesWell I ordered mine 10 mins after you looks like mine is still in China![]()
very nice to, looking good, how are your temps?
peak gpu 34 degrees
peak junction 57 degrees
test at the same as when on air
same settings on air gave me
79 degrees gpu
111 degrees junction
only single loop so that also cooling the cpu
Ordered a Sapphire Radeon VII from OcuK and noticed it had the same issue with the backplate not being secured correctly as was noted by someone else in this thread.
It's on its way back today and have ordered a Powercolor instead.
Here is a picture of the bracket of the Sapphire Radeon Vs a MSI Radeon VII i have.
Sapphire Backplate
MSI Backplate
Got about a 80mv undervolt with a 50mhz Overclock on the core at min
soon time to crank the core up
1 faulty, 1 i removed the stock pad and saw worse results so sold it to someone who would put it under a block, so i need a third.Matt why so many VII's? is this your 3rd one now. looking for a gem low vid one or better clocker?
At 2000mhz
Gpu peaked at 38 Degrees
Junction peaked at 70 Degrees
Setup your trust account, you can't talk about that here.Im thinking of parting with mine as I need to raise some funds if you are looking for a good one. Sapphire, 1038mv out of the box
Stable voltages on air
930 - 1802hz
970 - 1900hz
1038(stock) - 2000hz -
I think this one is top bin - under water I think it could be a stunner
Is there a market here?
At 2000mhz
