- 19 Jan 2003
- west sussex
Well finally my Bykski block has arrived in UK today
Good news! it wont be long now.
Make sure you upgrade that CPU as soon as you can. A Ryzen 6/8 core CPU with 3200Mhz DDR4 memory would be a good match, or an Intel equivalent if you prefer.Well took the plunge and ordered one of these, arriving Monday.
I assume it will work in a PCIe 2.0 slot for the time being.
Running a i5-2500k at the moment but going to upgrade to Ryzen 3rd gen when they are released.
I know it will be bottled necked but still better than a 450gts
Well my Bykski VII block arrived this morning by Royal Mail no custom charges![]()
Mine was attempted delivery with no custom charges as wellWell my Bykski VII block arrived this morning by Royal Mail no custom charges![]()
, was too lazy to get out of bed so will have to pick it up tomorrow
lucky you! fitment later then.
Well the VII is out of my water cooling system, and the rtx 2080ti is in the loop up and running, 2 things to note, on the rtx I used an EK block with back plate, on the VII I used the Byksk block and it has a much better flow rate than the EK one. plus the RTX EK block was no so easy to bleed the air out of. would be a right pain with solid tubing.
also pleased to report this founders edition has Samsung mem on board, seems the preff memory on the RTX cards. can still here air coming out from loop.
Mine was attempted delivery with no custom charges as well, was too lazy to get out of bed so will have to pick it up tomorrow
Mine is at the local deliver depot, in thinking it will deliver tomorrow...?No as still need to get more kit yet so might not be finished for a few weeks yet not really in a rush tbh
I can't wait, i'm pretty sure it will turn up tomorrow for me, my pc is already to go just need to drop this in and connect up the loop and join you watery people
I don't know what's going on with Alphacool. delivery has just been delayed to 60-120 days!!!! Might have to get a Bykski or EK instead.
I noticed this i had to shake the Whole case to help as had a air bubble in the block. cleared now and nicely bedded inplus the RTX EK block was no so easy to bleed the air out of. would be a right pain with solid tubing.
