Caporegime
- 18 Oct 2002
Thanks for the tips earlier in the thread guys, now settled on an undervolted overclock that keeps the fan noise in check
Thanks for the tips earlier in the thread guys, now settled on an undervolted overclock that keeps the fan noise in check![]()
Nice numbers! Let's see what mine is up to tomorrow.Just smashed my way into 4th place on 3dmark firestrike ultra with this water block on now, @2200 / 1250 @1150mv
The graphics score is 3rd highest from them all. This card is a beast
Yes. I almost didn't until I watched an installation video, then I panicked and put it on.Nice numbers! Let's see what mine is up to tomorrow.
Just got the block! Let me ask you something, did you keep the cross bracket?
Yeah two holes can't be used on the back plateI'm having a hard time here to put the bracket back. I thought in replace the original screws with the bykski on, but I got only 3 left, so that should be like this.
Sure! Let's compare some data. Tomorrow it's arriving a new pump and I didn't intent to put the card in the system now, otherwise I'll need to bleed it again tomorrow.
Perhaps I'll do tonight, let's see how it goes!
And for god's sake, whata kinda of manual is the one that comes with the block?
Oh, almost forgot. When you place the back plate back, two screws will become dumb as well? The two tops one each side
I'm sorry, thinking in one thing and writing another leads me to mistakes. I sorted the bracket out, it's fine. I thought I'd need to change the original screws of the bracket for the ones supplied with the block as they were very difficult to put back.Yeah two holes can't be used on the back plate
What is wrong with the x bracket for you? I don't quite understand .. You have 3 left of what
Look forward to your completion glad its all sortedI'm sorry, thinking in one thing and writing another leads me to mistakes. I sorted the bracket out, it's fine. I thought I'd need to change the original screws of the bracket for the ones supplied with the block as they were very difficult to put back.
It should definately not be the same score. Do you have chill, or some kind of v sync enabled?All set done and very unorganized. Tomorrow I'll sort this out.
Well, it's funny. Temps are great, running FS max JT was 68C in all 5 runs. There's also a overclocked 1800X on the loop.
Ran 1950/1100mV, same score than stock. Ran 2000/1150mV same score than stock again. I don't understand what would be the reason, and I don't have time tonight to look into it. With air cooling was not even possible to finish a test with 1950/1150mV.
Glad too see you have sorted it![]()
It finally arrived!
Fancy watching a pair of kids lol. Might get around to it this evening. I'll be glad to be back up and running as I was half way through Strange Brigade when my Vega 64 sold.That looks so different in design of the flow around the core, will be interesting to see your temps with this water block. very nicewhen are you fitting it?
It finally arrived!
