So I'm still getting this;
After further testing, this only seems to happen on cold boot and goes away after turning the screen off for 10 seconds or so. After that, it never returns no matter how much I reboot my PC or turn the screen on and off again. It will happen if the PC is off for an extended length of time, then rinse repeat and I'm back to ok. I've left the screen on for 10+ hours looping in a demo and it's fine.
I dunno what to do to be honest. On the one hand I really should return it - when paying over £1000 this is not really acceptable. On the other hand, the screen is otherwise perfect, very minimal bleed and no dead pixels. I may not be so lucky with my replacement & I've got 2 years to wait to see if it gets worse...
@Daniel - LG - any suggestions? Is this likely to get worse in your experience or will it stay like this?
Edit: Just looked, these only come with a 1 year warranty according to the LG site, but on OCUK it says 2 ... /confused
It's not very good; looks fantastic with it off though.
These screens are fragile and Kyle didn't handle and unboxed this monitor with that much care to be perfectly honest.
You are meant to slide them out of the box face down on the supplied support, attach the stand and gently lift it into place via the stand.
His video is how not to handle a monitor.
Aside from the issues, is anyone actually using the HDR on theirs? It's not very good; looks fantastic with it off though.
@Baddass if i send you a photo of the bleed with the specs (aperture, ISO, etc) could you tell me your opinion, if it's too excessive?
got the F model yesterday, coming from the AW3418DW. kinda concerned about the relatively high glow and bleed in lower and upper left corner - even at 26 brightness/65 contrast - damn that thing is bright AF (only had minor bleed in the lower right on the alienware.
i love how bright it is, love the wider gamut and higher refresh than the alienware. just not sure about the glow/bleed, i don't see it under normal conditions, but in darker games/movies, you know....what was seen, cannot be unseen. dammit.
