Status
Not open for further replies.
29 Jun 2004
hi chaps.
got a new car and the alloys are pretty dirty. Looks like i will need to take the wheels off and get right in there. Could you guys recommend me an alloy cleaner? many thanks
21 Jan 2010
Ceredigion
BH Autowheel is very strong, and capable. But to get fully into barrels and behind spokes you will always need to take wheels off.
Wheels off twice a year should be sufficient if you have a decent barrel brush though.
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
Ev0
Ev0
18 Oct 2002
Cleaned the alcantara bits on my steering wheel today (top and bottom sections, sides are leather), first time since having the car a month or so.
When I got it the alcantara was discoloured and the fibres were very compacted and flat, didn’t have a nice feel to it.
Bowl of warm water with some mild washing detergent in it, microfibre cloth dipped in and rung until it was damp and then gripped the wheel with the cloth reasonably firmly and rotated around the rim (similar motion to unscrewing a bottle).
Got so much dirt and grubbiness off it, it’s now a nice as new colour and more importantly feels like it should with the fibres feeling back to normal :)
Such a small simple thing to sort but makes the world of difference when it’s something you look at and touch every time you’re in the car.
Being an idiot I have no before or after pictures.
Ev0
Ev0
18 Oct 2002
Also on the subject of wheels, the barrels on mine are disgustingly dirty, not sure they’ve ever been cleaned properly!
I’ve got some BH wheel cleaner which has got some of the muck off, but feels like I need something more abrasive than my Halfords wheel brush to get some of the more baked in stuff off.
Any recommendations as to what to use, any sort of stiff brush that’s worth it?
Will need to get the wheels off and give them a good going over and seal.
Gor some wheel weight residue to deal with as well where previous ones have been pulled off and left loads of glue and crap behind :(
20 Feb 2004
Hondon de las Nieves, Spain
Well i can definitely now agree with those of you saying using snow foam isn't a lazy mans fix :p
Also struggled with the snow foam lance at first and it was just running off. I assumed the +/- would be the amount of foam so had it turned all the way to the plus. However after a bit of messing i turned it all the way to the minus and got a decent thick foam.
I quite enjoyed it though so i think the next bank holiday i'll buy a few buckets and things and do the job properly.
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
It's fine for a quick wash but I find that I still need to 2 buckets afterwards because there are still dirt on it (when you run your fingers over it you feel it even more), even after press wash it all off. So to straight dry towel on it would be a mistake.
It does make 2 buckets easier and get a much cleaner car but still need to clean it as before afterwards.
What has changed for me is the silicon spray products, after 2 buckets I now spray on those then pressure wash it off. That's my protectant seal as opposed to any waxes after drying.
Man of Honour
21 Nov 2004
:p at least you realised this. I also have my lance set all the way to the minus setting. That'll give you the best results. It is quite fun though. The best results are of course with a good sealant on the paint. I snow foamed my car (with wax on) and my wife's car (with no sealant) and the difference was night and day.
I think this is why I am leaning toward Autoglym's three step procedure. It just kind of works for me and means I can put minimal effort in and still get the best result.
12 Mar 2008
West sussex
pollen! sheesh does it stick to paintwork, both my cars are dark metallic and both look disgusting a day after washing.
do you lot QD them or go for a full rinse/wash ? :|
Man of Honour
21 Nov 2004
I know, it literally appears hours after washing - the main reason I can't be bothered with more than snow foam at the moment (which to be fair is enough to take the dust off this time of year).
18 Oct 2002
Anyone here used Gyeon can coat? I've been trying to use this on the Mark X with varied success. It seems to flash off almost immediately after application, I mean you don't really even have 2 seconds to buff it off. As a result I'm finding it extremely difficult to get a good even coat on large panels like the bonnet. In fact it went so streaky and horrible that I had to mop it again to get the mess off and then used a carnuba wax on that panel.
The panels with successful application though and a totally different league in terms of the hydrophobic-ness and it makes the carnuba look pants.
I did have a hard time buffing the polish residue off the bonnet to begin with though, the clearcoat was in a bad way prior to machining it. Maybe the clearcoat has some kind of permanent sun damage?
8 Oct 2008
Northamptonshire
Typically if the paint is fussy with application its best to dilute the product a bit with distilled water or similar.
V_R
V_R
17 Jan 2007
UK
Guys, my other half has has paint spots splashed down the side of her car by some pleb when he was painting the outside of a shop. :mad:
Its only tiny spots and its white pain on a white car so not the end of the world, but still annoying. What's the recommended way to get the paint off without taking the actual paint off!? Its on the windows too which I can just pick off, but any recommendations for products etc would be good.
Status
