I know DV247 is a German company. If I change country it's showing the 2017 model @ 888 euro. Click UK and its £1099 !!
It’s normal....and get it (or any purchase from them or Thomason) now because post Brexit you have to pay 20% on top.
Yes but the 2016 is 844 euro = £722![]()
Why is it so hard to choose what pedals go on your board! i have a pedaltrain novo 32 which is pretty big and still im trying to ram more pedals on there![]()
The solution is to get 2 boards![]()
The problem with pedals is that you’re effectively trying to hit an ever moving target.
I don’t bother with drive pedals because my amp can nail the tone that I love but I could spend an unlimited amount of money trying to get a good delay or chorus. When you think you’re happy you’ll find that you get bored or see the next shiny and convince yourself that you need it.
Sooner or later you’ll either build up a collection of 100 pedals and find that you can’t power a chain without some extra power boost or you double down and before you know it you’re only happy playing through a rack mounted plethora of processors and you’ll wonder why people bother with traditional amps when ProTools and unlimited plugins can turn a clean guitar in to any sound you can imagine.
My advice is to find a core set of pedals that cover 90% of the music you want to play and experiment with the odd pedal that you can rotate in and out. Get a drive, delay, reverb and chorus then keep the 5th slot as your revolving door ... be strict with yourself and you’ll soon find that most effects are just fluff and don’t really add anything beyond something to arse about with.
Jackson RR24 limited edition ive owned since 2008! Hardly ever gets played just sits in the wall hanger.. thinking about selling it at the moment but im sure i woud regret it if i did!
more pics here https://imgur.com/a/4omgmf6
I will give that a try as I do sometimes get sore wristsThe bit where it alternates between the two shapes at the end of that run is definitely a bit of a confusing finger twister! It’s deffo picked every note. I couldn’t do that at full speed. That said, I’ll try and offer some tips... even though you’re clearly better than INiceI will give that a try as I do sometimes get sore wrists
I'm still going with Master of Puppets, at this point I can blast through the whole thing properly at full speed all apart from that 2nd solo, which I can play at about 75% speed... That beginning lick I was asking about before I've eventually settled on picking 4 out of the 6 notes of each pattern, which gives it almost a slight sweep-like style and as soon as I did that, as well as concentrating on landing the 1st note of each pair of sixteenth-note triplets in the right timing and with the right emphasis it suddenly started to sound right and I can play it a lot faster...
The other part of the solo that I'm still not quite getting right at full speed is the ascending run of repeated descending triplets (if that makes sense) as you head towards the last part on the higher frets. Playing it mostly legato doesn't sound right but I can't quite pick every note fast enough either so still trying to work out what to do there
I have no doubt you know this but pick angle should be tilted in both axis... like this.
