Good tip, I may get a 4TB single one to replace my 2 7200rpm ones![]()
4TB single one like this , Seagate backup plus 4tb 2.5" ,Took it out of the External case
what size cpu coolers have people got in this case?
Thinking of shifting back to air from water, the spec says max is 160mm and the cooler im looking at is 159.4mm so should just fit but doesn't leave anything for margin of error.
I have the 101c, im using a Thermalright Macho REV B that is stated to be 162mm tall, it fits with a mm to spare so i guess InWin are being conservative with their 160mm claim![]()
How is everyone getting on with this case? I'm currently looking at purchasing one for a new build. Good thermals and space inside it for a more compact case?
I was looking at getting the Dark rock 4 pro cooler but I don't think it will fit. The size states 162.8mm.
I love the case, good thermals on both air and w/c set up, easy to build in, looks smart and is cheap.
as for cooler size best look at the last few posts.
