Is there actually a release date for this? Very interested but also concerned that I'd have the to change CPU cooler at additional cost. For such a wide case I was surprised to find that the max CPU cooler height is only 160mm. I understand some of that width is for cable routing behind the motherboard, but my current Define R2 is slightly thinner and does fit my Xigmatek Prime CPU cooler... just. Reckon I can squeeze the extra 5mm out of it? The Define R2 has a recommended 165mm max cooler height.
The case has actually already released, Stock is due in 2 weeks hopefully, assuming the sea is gentle
The cooler height is at most we can do, I will check to see if 165mm is doable but honestly very unlikely. Let me get back to you on that one
See the lengths we go to here at OcUK for our loyal customers
