the more round the bend needs to be. For that sort of door I would use standard or flat cat5e - it will give gigabit and as such is more than enough in a normal household environment.
All Ethernet cable can be routed like that. The higher the number of catsthe more round the bend needs to be. For that sort of door I would use standard or flat cat5e - it will give gigabit and as such is more than enough in a normal household environment.
I would use flat cat 5e for that ive seen network cables bend a lot more than that without issue
Flat cables can still have twisted pairs inside .Flat Cat5e/Cat6 cable isn't a thing - it relies on the twists in the cable to provide noise rejection. Any flat cables available don't meet any CatX specifications
https://sc01.alicdn.com/kf/HTB1Kr9O...TP-Ethernet-Cable-Flat-10Gbps.jpg_350x350.jpg
Is that a real wood floorboard or a click panel?
Either way it wouldn't be too much work to get a cable running underneath it.
Hi
I want to route an ethernet cable to my TV and set top box, but needs to go round this door frame.
Are any of the Cat5e/6/7 (round or flat) suitable for this?
Thanks.
You could just use powerline adapters if you have sockets near each point you want to run internet to. Work well and for a TV set top they are ideal and fairly inexpensive.
I don't know where you are looking but they are £20 on the rainforest site.I did look at powerline, but the ones I found (TP-Link) were between £60-£70 and I can get Cat5e cables and a 5 port switch for about £25
Used powerline adapters on The Bay of E are dirt cheap.I did look at powerline, but the ones I found (TP-Link) were between £60-£70 and I can get Cat5e cables and a 5 port switch for about £25
If its T&G which it most likely will be then he will have to cut off the tongue with a circular saw which is just not worth it in a high traffic area next to a door. Best thing is to take advice about powerline adapters for something like a tv but doesn't look like op is interested in that approach. I agree it is indeed a trip hazzard not to mention ugly looking.Lift the floor and get someone with a router to put a groove in the back of the board, lay the floor back down. I'd hate having cables run across a doorway like that - go up and around if possible. You're making a trip hazard routing things like that.
