AddedLets take another shot at the bottom of the board! I needed some files from the old machine and decided to see what Cinebench R20 would do on it. I wasn't sure if it would even run as ive come across some software (games mainly) that wont run on the old cpu. It is overclocked and im sure there is more in the tank but as its in a media centre case and doesn't really have the cooling I cant push it to its limit. The memory surly has more to give as well. I do miss the Activity leds. I wish we could see them return on modern memory instead of plain rgb effects that require software to control them.
CPU Multi: 254
CPu Single: 135
S939 Opteron 180 Dual core @3.00ghz 1.375v
4x Corsair 3500LL XMS Pro (2.70v - 2.5-5-4-3)
It says 3861 in the results, what's you clock speed?
Thank's, updated your submission.![]()
