8 cores will in the next year be the normal for new games. at the moment its 6. you wont suddenly jump to 12 cores as that would making games just not sell. they have to be able to sell to people.
think technically its still 4 cores. scroll through the hundreds released games over steam and find its 4 cores recommended or 8 threads high end, all dx11 and not utilising all the cores .
seems every one on here always quotes the AAA titles which still are poorly coded
6/8 core versions of ryzen 3000 should sell well, very well if they can hit 4.6/7ghz overclocked all cores and have a nice low price .
think i'll gun for which ever one can give the highest clock speed or match 9700k in 1080p high hz gaming for cheaper
you can still play most games on a high hz 4 core
People do more than play games. Anyone who does photo or video editing, digital art or content creation, runs any kind of server from their PC, (even if only for something like Plex or Serviio) will benefit from more cores. If it's there, people will buy it just because they can as future proofing, unless the pricing is crazy.
So PCIe 4 split up to drive multiple NVMe at full speed as we suspected, and 4GHz RAM OC. Cool cool.A hint of what's to come from other motherboard manufactures courtesy of Biostar, (Videocards link).
Phases: 4 + 2
PWM Controller: IR35201
CPU: 8x IR3555 interleaved with IR3599
SOC: 4x IR3555 interleaved with IR3599
Intels response.
There is only one way to respond and that’s price drops
But active cooling on the chipset? Oh God...
Apparently the chipset does use a smidgen more power, but enough to warrant active cooling? It better not be a loud fan if this is an X570 thing.I hadn't noticed that until you mentioned it, what's up with that? Could it be the chipset AMD designed is running hot or could it be a Biostar thing.
Define "performance".I'm bored with Zen 2 by now so when are we going to see the next real innovation that pushes performance significantly?
Anything on the horizon?
Zen 2 is important to me due to power efficiency and more than likely cost.
Both are very important metrics but not that sexy.
There does seem to be a lot of PCIe 4 lanes running off that PCHYeah chipset fans, nah
I guess there is only so much data you can push without active cooling
We're not getting higher frequencies any more, in fact we may see frequency regression. 6nm and 5nm nodes are coming but that's going to be power and area saving. Silicon is at its limit for pure number gains. Modular designs with chiplets are the way forward for now until some new material can be used, or we go full-on sci-fi with Quantum computer or biomechanical.
But to be honest if the concept of a truly modular approach to systems design with chiplets and 3D stacking technologies bores you then you might want to explore other interests. How did you not lose your mind at that 15-chiplet Milan package speculation?
