- 30 Sep 2005
Never wash your car in direct sunlight.
It's detailing 101.
Yup, I know this....but was rushing and totally forgot about the water spots....which makes it even more frustrating
It's detailing 101.
Do they stipulate what condition it should be in before you take it. I'd expect a full correction before coating anyway.
Did you not dry it with a MF towel ?
I've given up on all those fancy shampoos, cost far too much and even when they say they're concentrated they lie.
Car-Chem Super Suds Shampoo is all i use now. Got 5L and it will probably last me my lifetime. You even get to choose what it smells of.
Fair enough. Better value than most.nothing fancy about that, simple 550ml bottle for £5
doesn't try to wax, "power clean" etc just a basic shampoo that does the job well and lasts ages with that 550ml.
Just collected my car from having gtechniq ceramic put on. Can't help but feel I've wasted £500.
There's little bits here and there, the detailer walked around rubbing them out with some fine polish, maybe caused by the c2 finishing layer.....but I kinda expected a bit more for my money.
I already have a line of water spots caused from (I assume) the rear wheel when I was driving home. It feels silky smooth to the touch, so who knows. Can't remember seeing it when I collected it. Unsure how best to remove it?
He did send me a link where I can buy some stuff from which he says is ceramic friendly:
https://www.cleanyourcar.co.uk/carp...uY03NIm2gpwNe9yJdYGNy5vOTREdrN7eWQORmg#183=13
Thing is, I thought detailers were absolute perfectionists and got your paint night on perfect? He's had three full days on it, and I can see bits within the first 5 minutes.
am I expecting too much?
Is £500 for a full machine correction and ceramic coating a bit cheap? I'm sure when looking at prices a full machine correction alone would be more than that.
Who did you use?
I'm sure everyone has a preference but just after some advice really, would the above be a solid choice or anything else worth considering?
I'm in the market for a Snow Foam Lance and some Snow Foam to go with it!
I've come up with the following...
- Autobrite Snow Foam Lance (Includes 500ML of Magifoam)
- Magifoam 5L "OR" Bilt Hamber Auto Foam
Well, in your shoes I wouldn't be too pleased either.
Maybe mention it to him now if you didn't at the time? You've noticed a few marks since having the car back and is that normal after the work you paid for? See what he comes back with.
It's a new car so only needed a prep and perhaps minor work. I'd rather not name and shame as he's an old friend. He's got a proper premises and done no end of Ferraris, Porsches, Audi r8s etc etc
Just wasn't sure if I was being a bit unrealistic in what to expect.
