Em... Not for you it's not. You don't speak for everyone. Why on earth would you WANT a component to get so hot it needs active cooling rather than run cooler and not require a fan? That's just ridiculous.
I've had chipset fans in the past and I can tell you they are audible when running.
You don't understand why the fan is needed in the first place. It can be because without it, the temperature would go easily over 100°C, and with it and very little flow, the temperature can safely stay up to 80°C.
Better not to comment
