You are just as bad as the people you rail against. Lapping up things that are clearly by any metric nonsense because they support the picture you want to see, even if ultimately that picture itself is the right one, and when called out on it try to write me off as "invested in the clearly nonsensical official line" despite my posts clearly showing anything but that.
EDIT: And as if to prove my point:
It is hard to take you in any way seriously after that tripe.
EDIT: I will actually break down some of that though:
While this was true for most of Ghouta province the rebels in Douma had not agreed to a negotiated surrender by the end of the 31st March ultimatum as was announced to be so on Syrian TV and over the next few days an agreement was come to for the evacuation of non-combatants and wounded but by the 3rd or 4th of April the rebels turned down any further talks on surrendering leading to renewed air and artillery strikes from government forces on the 6th to soften them up for an offensive on the 7th - on the 7th despite making a lot of ground government forces were still facing stiff resistance and once again repulsed with heavy losses including several more tanks, something they could poorly afford to lose, when they'd already lost more than a dozen in assaults on the area. Not quite the picture you are presenting.
Defeat was inevitable, a few days longer would make no difference but huuuurrr deeeerp gas them even though in EVERY PREVIOUS CASE in the previous weeks they reached a negotiated surrender and they were bussed to Idlib.
As long as it makes sense to you.
As I said before you are invested in this nonsense for some reason.
