It was one of yes, but unacceptable for a board that expensive to encounter such a fault.The Asus Crosshair IV was pretty much the best AM3 board though.
You need to brush up on your comprehension skills then, sunshine.I see a lot of Gigabyte Bashing on here...Much Asus Shilling![]()
A shame AM3 had no exclusive CPU's
A lot of the cost of Asus boards is in the name/branding - even on their expensive boards/products I've encountered premature part degradation far too often and they will happily replace a brand new expensive "premium" product with shoddy refurbs that probably do the rounds until some unlucky customer gives up and just accepts it.
https://twitter.com/ASUS_ROG/status/1128993503248355328
The Asus teaser vid seems to hint it doesn't have a fan, but it's hard to say.
/offtopic In the days of ABIT and Supermicro, I would not touch ASUS.
AM3 had exclusive processors - Phenom II, Athlon II, Sempron and Opteron which were supported on AM2+ and AM3 boards.
I see a lot of Gigabyte Bashing on here... I've not had any big issue with 2x X370 K7's with 1800X chips using b-die, this is infact an 'overclocking forum' and as such I would expect a good portion of people to know what they are doing with equipment. I'm tunning F31 Now and am having a very good response to memory with less voltage needed for the CPU as well.
the new gigabyte bios added the option to enable PCIe 4.0 on the x470 board.
https://www.tomshardware.com/news/gigabyte-amd-ryzen-3000-pcie-4.0-x470,39377.html
Out of all the motherboards I've owned over the years flaky Gigabyte bios is a pain in the **** and getting next to no support from Gigabyte as the only fi.x was to swap out the motherboard which they refused I had to shift through endless comments of **** on the internet saying exactly what you've said. It's amazing how all the problems I was having went away when the gigabyte board was swapped out for an asus one.
What really ***** me off is that someone started a thread on here with a Gigabyte problem and was able to get a RMA with no reciept/proof of purchase which is great that I purchase a companys products and basically get told to go do one while people who could've got the item from anywhere get the support.
I will buy only a board with active cooling on the chipset.
