Nothing like getting knocked while cooking a nade near your team mate! Then the nade takes out both of youi've been that nade wielding tool
i remember playing erangel, last 2 circles only 2 of us left and no sign of the other player. last zone stopped near the right bridge to mil island (if you're on the island looking north) i was at that point running round in the open wondering what the hell was going on.....dude eventually dies to the blue. replay showed he had tried to sneak round the cliffs but slipped down to a point he couldn't get out. all the more enjoyable as it looked like he was using the radar hack.....he kept looking to my position even though he had no line of sight.
few games (maybe a night) later i'm in almost the exact same position.....3 left and i'm on the rocks....sods law, i fell off too and was trapped....3rd guy gets popped so just me stuck and waiting for the blue to kill me......randomly lobbed a smoke nade into the air to kill time waiting to die (no bang bang nades) and like a moth to the flame i hear footsteps approaching, thinking my death is pending to either the blue or the other dude i lobbed another smoke, and like a scene from a comedy film this head pops over the rocks almost directly above me straight into the line of sights of my m4. i imagine he was properly raging!!
that's the thing with pubg, for all it's problems and bugs there's no other game can produce the same level of excitement and silliness, often in equal measure, that it does.
try stock clocks and see if crashes. also try older gpu driver. also try verifying steam files for pubg. you may have to redo your cfg though if you do this. key settings and so on
This game crashes for everyone of my friends that play this game occasionally but if yours is near on every game I would be looking at hardware.
What is your RAM speed? I'd be looking at stress testing the CPU or RAM to try and narrow it down
i think the ram speed is 1600. I dont think i mo can take faster.
I have run haven, kombi (afterburner one) and didnt have any problems. but that was them running for around 10 mins, not sure if this is long enough?
i have tried the steam file, and it didnt make any difference to the crashing.
I just played 3 games now, and it didnt crash once. the only problem was venkdi was jittery and the fps was dropping down to 50 or so every now and then
Both them tests are very GPU heavy. You'll want to run something like prime95 blend test that will heavily stress CPU and RAM and normally show up any instability. You'll want an older copy of prime95 that is non avx and keep an eye on CPU temps as they will be a good bit higher than gaming. It will also need to run for a few hours
just return pc to stock play. see if crashes. if it doesnt its overclock most likely or gpu driver.
you validated files so wont be game. do you have any overlay ?
forget the stupid benchmark progs. just make pc default work from there. my guessing more cpu voltage or...bad gpu driver. use older one. like 388.13 do fresh installation. custom and only the driver and the physix ticked.
