- 15 Feb 2009
- Bristol
Ok thanks. I'll leave it then, don't want to go poking around in case I mess something up.
What's your take on brake seals/hose? Service manual says to change them every 2 and 4 years respectively.
And where do you get the sump plug washers from? I've been looking around but can't seem to find one specifically for the YBR?? The only thing I've found is this from eBay: https://www.ebay.co.uk/itm/Yamaha-YBR-125-ED-2012-2013-CC-Oil-Drain-Sump-Bolt-Washer/400877634658 And even then, will it fit my 2017 model?
