I suspect it’ll be closer to £600.
if the performance is there then i'd spend up to £800 for the 16 core, if it dropped at £600 that would brilliant, really **** up intels offerings XD
My budget is 1k for chip, board, ram, new storage.
I can go over a little, so for me I'll buy on price and will be picking a cpu probably in the region of £450-£500.
Jesus wept.
New 6 core 4ghz part beats 2700x..!!?
https://wccftech.com/amd-zen-2-6-core-cpu-benchmark-leaked-faster-than-ryzen-7-2700x-in-geekbench-4/
2700X on a single core boosts to 4.35Ghz, correct me if i'm wrong.
If the 3300 is running at 4.0Ghz, as stated then:
2700X @ 4.35Ghz 5.061 (+2%)
3300 @ 4.0Ghz 4.923
4.0Ghz + 9% = 4.35Ghz
So the IPC is up 7%. on a very mixed benchmark FP + Integer
It's wrong. The 2700X normally scores around 4800 single-core. That 5061 is when all cores are overclocked in which case you can't compare with the 4.0 GHz boost clock of the Zen 2 sample.
Are you sure? add 5% to 4.800 you get 5.021 add 5% to 4.35Ghz you get 4.57Ghz.
The highest usable all core overclock i have ever seen on a 2700X is 4.4Ghz running on may gaming mates top end Asus board.
Another one with a 2600X has it at 4.3Ghz
2700X @ 4.35Ghz 4.923
3300 @ 4.0Ghz 5.061 (+2.8%)
Well I just derailed that for my Polish forums. 2700x score on that Bullcraptuicle is Lower than it really is on stock cpu on mine score is like this2700X on a single core boosts to 4.35Ghz, correct me if i'm wrong.
3300 @ 4.0Ghz 4.923
My single [email protected] is still Higher than what they shown and that does not boost as high as stock 2700x as You mentioned.
They ran that 2700x with 2133cl18 memory or something![]()
Look at Multicore score on my system vs what they got in there.... and as mentioned I'm Lower Single core boost than Stock 2700xWell yours is 1.7% higher, i'd call that a margin off error and you're running a different version.
8700k score asked my mate to run it. Guys on that can sleep no problem. So I need to Download older version You say BRB !!!Your score is with DDR4-3600, the Zen 2 score is with DDR4-2666.
Your version is Geekbench 4.3.4, the tested one is 4.3.3.
