What the hell do you lot see in the 9900?
I see a pushed past the max chip with huge heat and power problems on an old platform with no future and the best of all so badly compromised with security it doubles as swiss cheese.
Exceptionally naive to be buying into such a bad product when you will have options elsewhere especially for the stupid money intel wants.
I bought one fairly recently. Was holding out for a 3950X (or whatever Ryzen 2 16core will be) but needed to rebuild a second system and decided for all round use, especially gaming and likely resale appeal it'd be a decent buy. Thought I'd regret it but I now don't see the 16 core Ryzen 2's coming until September at least so glad I did.
While I don't disagree with what you said, for what it is, it's still a decent CPU and at the moment the best for gaming which is not hugely important for many including me if I'm honest, but still a strong point nonetheless. It shows what Intel can do, which is to just about stay ahead even regurgitating the same old ****
Not bothered overclocking it but see no higher than 75c using an air cooler. It rarely hits 5 Ghz though, even if running cinebench on a single core. It's working fine and hits it more frequenty if I kill off a load of threads in task manager, so it seems even very low load on other cores causes even 2 cores to throttle back from 5 Ghz.
What amazed me after previously installing a 1950X is how small the 9900K is. Tiny. Not really sure why but just assumed it'd be a bit bigger.
