- 27 Aug 2009
- Liverpool
haha not quite there yet 1 last graphics update was a biggie
Well, this is really looking promising now.haha not quite there yet 1 last graphics update was a biggie
Are you sure Windows isn't updating and muddying the waters...just booted up on game boost mode, something just doesnt sound or feel right tho when game boost is off
Download Core temp - would like to know your temps as we slapped the CPU back on without reapplying TIM. I'm sure it will be OK - but will be happier if you had that installed so you could monitor temps; now and for when you first stress the CPU.
Doesn't start up - or goes to start up switches off and then starts normally?but pc was completely turned off...when i turned it on (without game boost) it just doesnt start up
Can't make my mind up if you're describing a normal start up - as the system does a self evaluation/check - stalls then starts.it kind of chugs if that makes sense, fan spins but then gives up, but then spins abit faster looks like its starting up loading screen but then restarts its weird
Windows updates?xmp - is that a bios setting? will have a look and get a quick video, still plowing thru these updates so many of them
Could be the case as fits the symptoms he's describing - to date.I wonder if Game Boost (which can increase the Vcore quite dramatically I've heard) is masking a CPU power delivery problem, by forcing more power to it than it should need right now.
HWiNFO64 pretty much does that.can any of you recommend a good driver software i could install that checks everything?
