Everybody loves a happy ending![]()
Dirty bugger
Had one of those yesterday, not as close as yours, but the crucial difference was that the car who wandered into my lane had absolutely no reason to do so as his lane was clear in front of him. Gave him a couple of flashes in the hope he'd move back, instead he brake tested me and gave me the finger. Unfortunately, he'd failed to notice the police car about 1m from my back bumper. I reckon the officer would have overlooked the pulling out as that sort of thing happens every journey here, but he was most unhappy about the brake test. Came back the same way a couple of hours later and they were loading the guy's car onto a recovery truck, guessing he didn't have tax / insurance / license. Karma![]()
Haha, If you're thinking what I think you thought I meant, then it's you that's the dirty bugger.Dirty bugger
In that scenario, can you claim off the other persons insurance for damages to your car in order to avoid collission?Awesome!
But yeah at one point I thought this is it, not for me, but for my car certainly! Fortunately a combination of standing on the brakes, leaning on the horn, and steering right to the curb of the road, were enough to avoid a colission by mere inches.
If I were in the E30 with its lack of ABS and vastly inferior brakes, I'd probably be in hospital and my car would be toast.
Sub 2000rpmWhere’s/when’s the misfire
It can be done but good luck proving it was 100% their fault.In that scenario, can you claim off the other persons insurance for damages to your car in order to avoid collission?
Dashcam enough?It can be done but good luck proving it was 100% their fault.
I don't think I've ever heard of anyone successfully doing this, insurance companies like to wriggle out of things and -technically- any damage caused by avoiding an accident, was your fault. As cynical as that sounds...It can be done but good luck proving it was 100% their fault.
This would be interesting to know. I suspect it depends on the individual case.Dashcam enough?
Yeh think of those poor bearings. Fuel might help actually. A few people have issues on momentum on the s65Sub 2000rpm
4,5,6,7 gear.
You wouldn't normally be in that gear at those revs when accelerating hard, but you should still be able to .
No fault codes, spark plugs and Lambda sensors have been changed.
Mostly points to cool packs but will look at running a few tests on them next.
Sub 2000rpm
4,5,6,7 gear.
Discovered some **** had hit my car while I left it at the train station. Parked right at the back of Havant station, in a single space away from everything else and still some **** manages to do this. Didn't notice it at first, only when I went out to the shops and noticed a huge white scuff on the front. Most of it wiped off but it's still left looking like this:
On the plus side there's no dents, cracks or gouges so it should be straightforward to sort out. Not sure it's worth getting a full bumper respray so I'll see what luck, if any, I'll get with smart repairers. I had much worse repaired on one of my older cars for £200 so here's hoping I can get it done for less than that.
People who cant park tend to find quiet areas to park in.
My mum, for example, would have parked next to you.
Drained the gearbox, couldn't get the fill plug off! hilarity ensues...
You should only drain after the fill port is open tbh.Drained the gearbox, couldn't get the fill plug off! hilarity ensues...
