You're quite right. I just replayed it again and heard him making that same inane point. Even the Sky commentators, in their desire to have a competitive race, didn't quite grasp this point and only grudgingly accepted that the stewards could have been right.It was worse than that, he moaned that if he'd done anything else he couldn't have blocked Hamilton and he'd have got past. Well, yes, that's kinda of the point, dear boy.
Well I play football as a hobby and can score a penalty just fine, but could I do it in a Pro match with the pressure turned up - probably not. Maybe you should send your racing CV into Mattia BinottoRegardless of watching it on my TV I have a motorsport hobby and can handle surface changes just fine thanks, and I don't get paid millions to do it.
Is there precedent for over turning in race time penalties?
It would be interesting if this indeed happens, as if he hadn't had it, would Hamilton have tried harder to get past?
Is it weird that I watched a clip of the incident on mute, during my lunch break and heard SHOUTY CROFTY in my head
I even checked the volume to make sure I didn’t just have it on low and was convinced I could hear him shouting.
Well, apparently, it was important and they do have it: Vettel Steering Inputs Key to FIA penalty decision.
He forced Ricciardo to brake to avoid a collision. Vettel left Hamilton room too, pic here
The point I was making was that you can defend after making a mistake and you absolutely don’t have to give up the position
No he hasn't, all 4 of Hamiltons wheels are over the white line and therefore off the track.He forced Ricciardo to brake to avoid a collision. Vettel left Hamilton room too, pic here
Quite right. See here...The Stewards clearly made the correct decision, not sure what all the fuss is about.
...The movement to straighten the wheel, which put the Ferrari into the path of Hamilton's Mercedes, is believed to be key to the unanimous decision by the stewards to punish Vettel.
The stewards also used an extra CCTV camera view of the incident, which was not broadcast on the international television feed, showing Vettel moving his head and looking in the mirrors to see Hamilton was during the moments when he was releasing the wheel to the right.
On board footage of the Vettel incident also shows his head turning towards the mirrors in the moment when he is drifting out - suggesting he knew where Hamilton was.
As an F1 fan I would like the racing to be decided on the track and not in an office where a committee decides the outcome after referencing rule x.y.z. Just let them race and stop all of the silly interventions whenever a 'racing incident' occurs.The Stewards clearly made the correct decision, not sure what all the fuss is about.
Hamilton never overtook in the race. So, why the win for him? Because of some virtual potential that he could have overtaken and kept the lead. Which is ridiculous.
The penalty was stupid.
They should have forced Sebastian to move to the second place, so Sebastian could have had the chance to take the position back.
Bets on how long it will be before Vettel buckles under pressure, makes a mistake and gives the lead away?
I’m inclined to believe what people who have actually been there and done it think. Webber, Button, Andretti, Mansell, Wurz have all said it was daft.
Andretti makes a good point:
He has to keep the car straight, if you start turning on grass you will probably slide and lose the back end. He has to keep the car reasonably straight and can only turn once he gets the wheels on the tarmac. If you watch the onboard you can see his steering wheel snap turn left due to having no traction and he has to correct it with right steeringIts pretty damning.
Vettel’s problem is that he keeps making mistakes, not the stewards stealing wins. Vettel could have kept further to the left on the grass. This statement confirms that he dived onto the track to try and stay ahead and, as a result, got a snap of oversteer that meant he nearly put Hamiton in the wall. If he kept further left Hamilton would have passed him on the racing line. Penalty was the right result. Would have been less aggro if he had just let him by.
Case closedQuite right. See here...
I'm pretty sure they haven't seen all the telemetry and camera angles that the stewards did.
Says who? Link??Stewards do not have access to telemetry during the race, telemetry is only used to analyse when a decision is made post race.
Yeah ultimately he is to blame for making the error, after last season I wanted to see him sacked because he's not world champion material at Ferrari.Highly likely he couldn't turn on the grass, but the problem remains that once he gets on the tarmac he turns the other way. Whether to intentionally block Hamilton or correct his oversteer, who knows. Looking in his mirror to see exactly where Hamilton was hasn't helped his case. It also hasn't helped Vettel that Hamilton made no contact or lunge at him, he went off all on his own, then impeded Lewis as he rejoined. Why wasn't he just asked to give up the place? He at least would have had a chance to get it back.
