Permabanned
- 15 May 2006
- London
Actually there was and still is a huge amount of difference between them :
https://forums.overclockers.co.uk/threads/the-official-ocuk-cinebench-r20-benchmark-thread.18849380/
Unless you are saying that all those with fantastic clocks and fantastic ram speeds running 2700's just couldn't be bothered to post them ? I don't think so.
+1Possibly a better all core boost on the 3800x?
This is the point isn't it? "the 3800X removed the CPU bottleneck" the performance on screen was higher than the 9900K but only just by a couple of frames, if they "removed the CPU bottleneck" then its not indicative of the CPU's performance compared with the 9900K given the marginal difference, if the GPU is the bottleneck.
HWBOT World Records.
Cinebench R15:
9960X: 5320
3950X: 5344
Cinebench R20:
7960X: 10895
3950X: 11101
I’ve not read the whole thread but there aren’t any 2700 results posted in the top 50.
Average clocks on Hwbot are a bit higher for the 2700X but then if you’re going to be clocking them most people will buy the highest bin.
What’s the reality 100-200mhz on air? Same on water?
Beginning to think this is likely3950X $750
I bid $699, a little cheaper than thread ripper.... though $500 would be betterBeginning to think this is likely
iT WILL BEAre we expecting the 16C to be shown at this event?
Is it on YouTube?Anyone actually watching the E3 stream presently btw?![]()
Is it on YouTube?
Cheers found it on YouTube. I like the dog.Yes, loads of streams, Twitch, Youtube etc. Ubisoft is on presently.
