Permabanned
- 11 Jan 2019
- bedlam
They said under normal used the fan will be off. And the temps only get high when running m.2's in raid and or benching said raid set up.
https://www.anandtech.com/show/12625/amd-second-generation-ryzen-7-2700x-2700-ryzen-5-2600x-2600/5The other odd thing about your analysis is that you state that the node shrink will have directly benefitted the per core power consumption, yet we know that the 2nd gen weren't consuming anywhere near the 12.5w per core that you're attributing to the 3950X.
True, but it's also at >80C so either they are over clocking on the box cooler, or it's pushing some power
I wouldn’t get a 6 unless you’re happy to replace in 1 or 2 years when it starts to get hammered in games
Very, very interesting if true: http://tieba.baid
Their actual data shows all-core at 4.0GHz and 10.5w per core, and the gains from 7nm itself may only be 20%...and directly on the per core level. However, what you've failed to address is that we're comparing a GF node with a TSMC node; one of which was operating significantly outside of it's optimum frequency curve.
My whole point is that I don't think we should be using 2nd gen Ryzen as a reference point here; there's too many differences to be relying upon it.
The picfure shows Sunnycove at 3.6GHz pretty much matching current top-tier single thread performance regardless of whether we're looking at current AMD or Intel.Very taxing bench Cpuz lol
此图为3款Ryzen 3000系列cpu在cpuz下的单核跑分成绩,及一颗2700x锁定4.35ghz的跑分,对比其他Intel 11款处理器的成绩
translates to
This picture shows the scores of the three Ryzen 3000 series cpu in cpuz single core running score, and a 2700x locked 4.35ghz running score, compared with other Intel 11 processor scores.
translates to
AMD: 3 weeks till ryzen 3000 Linus: "Time to upgrade to a 9900k"
The Anandtech article says something along the lines of "we initially turned Precision Boost off in our early tests, but that was because we didn't understand what it did." The implication being that it was on for the tests in that particular article. One of the first graphs on that page of the adticle shows that they were getting 4.0GHz across all cores. The later table confirms the power draw through the cores when all cores were loaded.There is an AMD stock slide that's shows 4Ghz, however I didn't see that confirmed in the text that it's what they used. With OK cooling many will boost to this.
I'll have to disagree on the process changes based on the TDP Vs clocks AMD has shared. The clocks they shared for the 3800X are the best they will guarantee at 105W and only a small increment (5%) from 2700X so I think the 2xxx is sufficient for indicative comparisons.
My original comment was that 4.5Ghz on all 16 cores on air was unlikely as air coolers start to run into limits around 200W and even at 200W you need to be moving a lot of air so it's not an ideal solution.
Based on the data we have available, including 3950X @ 5.2ghz on LN2 where 2700x hit 6Ghz on LN2 suggests in incremental per core improvement in frequency/power and that despite the 105W TDP on the 3900X and 3950X we will need high end cooling to get the best from them.
Then you still have problems in telling the difference between AC and DC.Well if you want to be a pedant, I could have typed 'power usage scales exponentially with frequency because in 30 years of overclocking I've yet to find a CPU where you don't need to ramp up the voltage with any significant overclock and this has a drastic effect on power usage.
I love this little comment......
Overclocking makes power consumption rise linearly with clocks. (actually less because affecting only dynamic consumption and only cores)
It's overvolting which makes power consumption bloat exponentially and even without any clock increase.
I had 1.25VID Q9550 which I undervolted to 1.2V and overclocked fair 30% to 3.7Ghz+change.
Now that was real overclocking.
Time of that that overclocking loose in CPUs is well past.
Now all this hyped over"clocking" is really mostly just brute force making of e-penis space heaters with small performance gains for high power cost.
Making no sense for average user.
And in gaming depending mostly on execution speed of few most heavily loaded threads manual all core clocking is even challenged by automatic boost clocks.
Which basically automatically utilizes that reasonable clocking room.
it was sponsored by NVIDIA and gigabyte though. Its hardly a bad choice as much as AMD should be very competitive against it.
