it was sponsored by NVIDIA and gigabyte though.
Well their next CPU is two years away desktop-wise, by then AMD will be prepping Zen4 while having Zen 3 out i believe, so it wont matter.
Recent LTT videoWhere was that comment from?
You should understand that IPC gain includes AVX-512, if you are going to expect that IPC uplift on programs we usually use, you are going to be disapointed... Also their 10nm is showing 1Ghz less than older 14nm++. On desktop it is also going to go against Zen3 not Zen2.The leaked slide https://wccftech.com/intel-10nm-ice...met-lake-amd-ryzen-3000-cpu-z-benchmark-leak/ gives the SunnyCove on average 18% IPC betterment over Skylake.
You can see that Comet Lake is essentially the same as Coffee Lake, as expected, but "Sunny Cove", which is meant to be in their 10nm CPU, looks to have a large IPC bump finally. The question is how long it'll take for 10nm desktop parts to appear.
I have no doubt Intel will see a good IPC increase, but that good? I'm not sure. I just want my 3900x now, k?
+1 lolGonna get a 3800X and sell my 2700X on the MM![]()
Hmm.. thinking of holding onto my 5820k which still performs well for me, USB 4 next year and DDR5 (possibly..) might just get them all at once with an even better uplift in CPU perf if Intel release SunnyCove next year, more competition. Are Intel even able to bring it forward that much though? Thought it would take them another 2 years or so.
