- 18 May 2010
- London
Single thread IPC gains can be seen here.
Tell us about power draw on a max overclock 16 core part. Does it cause issues? on Taichi?Taichi is decent I tried it pretty hard. Eff is good upto what you need and CPU OC is also fine....
CPUZ single thread bench is utter rubbish!! Applies to nothing!!!
Interesting the Taichi isn't ideal for 2 Ram sticks and will prefer 4 sticks. I wasn't planning 4 sticks.
In the past the T-topography has not been so good for 2 sticks but better for 4 but I would think this was due to weaker IMC in the Ryzen 1 + 2 chips. If the sweet spot is around 3733mhz but using a divider on the infinity fabric allows you to go higher to 4500mhz+ this may be the better way to go. We will have to wait and see the reviews.
I'd be quite happy with a "all the tweaks, none of the fluff" options board too. If one emerges with a good bios, I don't care who it's from... they get my business and I'll be fairly loud about lauding them for their design choices too.
EVGA dark X570 would be perfect.
Same boat - 10GB lan is nice but... can be added later.
Sound - I don't need.
RGB - can go die in a fire.
VRM's and good control/bios - YES, MUCHLY!
IF these are right...Single thread IPC gains can be seen here.
AMD showed that latency increases again when going 2:1 so will certainly need reviews
3733Mhz = 1:1 = 3733 on IF
4500Mhz = 1:2 = 2750 on IF + increased latency.
Depends on workload most likely also; as games tend to like lower latency; but maybe we're all in for a surprise in reviews if they do some proper memory testing.
At the moment I'm eyeing up Team Group 8Pack 3866Mhz 16GB; as should be able to run at 3733Mhz with decent timings; but I'm not buying anything until I see reviews.
According to AMD 3733 is best place to be due to how IF works. We need banchmarks if 4000 will cut it but i think would need like 4400 to make up performance lost due to divider. Also Zen architecture is about timing not as much mhz 3200cl14 is faster than 3600cl16 TESTED.According to this Ryzen 3000 should be good for 4000MHz ram.
That's:
IF clocked at 1866.5 MHz with DDR4-3733
IF clocked at 1125 MHz with DDR4-4500.
They said DDR4-3600 is the optimal solution which I guess means peak performance out there.
Have You had time to play with timings ?? That's most fun part of owning Zen for me. Since Last 2 gens ware well not lets say high clockers even on my binned chip spent more time doing that while doing squats watching em numbers flyI tested all this stuff already..... The mems you have will be fine......
3733 is 1866 IF actually......... 3600 1800 and blah blah blah......
It's not wise to extrapolate like that.As a side note CyberPunk 2077 demo system used 32Gb of ram. So from next year we may need more ram.
I dont think 4x1 was ever better than 2x2 on memory on any platform without quad aka HEDT platform.Any idea on how 32GB 2x16GB would run? Or would 4x8GB be fine?
You only seem to have a single 32GB 8Pack kit on the store.
