So strange to see one half of the market doing very well, bringing out new products and a potential price war about to take place, and then on the other side to the graphics market we see a complete mess filled with overpriced products and minimal performance increases.
Yeah the graphics market could be much healthier. Fingers crossed Nvidia drop prices.
Intel dropping prices means that AMD must be doing something right this time, evident by them advertising RAM that is basically plug in and it works for a start, which is how their chips should have been to begin with.
Pretty telling... Intel did nothing when Zen1 and Zen+ released, all they did was release superior performance (read performance, mostly single threaded, and worse security) CPU's and put up prices...
AMD bring Zen2, Intel drop prices, pretty much tells you all you need to know.
I don't like the Vega 56 or Vega 64 because they are supposed to be faster than GTX 1080 Ti but actually they are lagging quite a bit behind.
When were either supposed to be faster than a 1080Ti?
I thought ram prices were going to drop as well but they seem to only have increased.
Also, when will we see price drops? The Intel chips are still holding strong
Not to mention I simple do not want to buy something expensive with serious security flaws that will have to be patched, which is likely to cause the CPU to lose additional performance over time.even with a 15% price reduction I still think that Intels cpu are overpriced compared to the competition.
Nothing is better for the consumer than fierce market competition.Healthy competition.
Earlier
We don’t have a lot of info when it comes to VEGA, but when we looked at their pro GPU’s benchmark it wasn’t very good, as it lacked behind the GTX 1080Ti in the newest ghost recon, which tends to favor AMD over NVIDIA at this point. We do expect the consumer flagship VEGA to be better than what the pro-GPU can do at this point when it comes to gaming, and I believe we can expect the GTX 1080Ti and the VEGA flagship to match each other. Pricing will most likely not be too different, I’ve brought the reason multiple times, but IF VEGA implements the “infinity fabric” well in their new GPUs we can expect the new VEGA flagship to be a BIT cheaper, but not by much due to the fact that VEGA will be using a completely new architecture and not the same GCN architecture we saw in the 28NM node. Driver support is also difficult to tell, while AMD supported the 28nm GPUs better than NVIDIA did with their keplar GPU, we also have to consider that they won’t be sticking to 1 architecture with a few revisions like before, so we do not know which card will age better.
- VEGA-WHAT CAN WE EXPECT AND PRICE?
The performance won’t differ much when it comes to the VEGA flagship and the GTX 1080Ti, we can expect similar price due to the die size and the newer architecture but we can also expect some good deals with VEGA’s infinity fabric! All in all, there won’t be much of a difference and it’s all up to you, in the end it’s about if you want to support AMD or if you want NVIDIA’s technology like soft-shadows etc. (which might get open source soon, but I wouldn’t hold my breath).""""
- CONCLUSION
https://www.quora.com/Will-AMDs-Vega-be-better-than-Nvidias-Geforce-GTX-1080-Ti
AMD RX Vega 64 Outperforms NVIDIA GTX 1080 Ti By Up To 23% In DX12 Forza 7 https://wccftech.com/amd-rx-vega-64-outperforms-nvidia-gtx-1080-ti-23-dx12-forza-7/
Earlier
- CONCLUSION
Earlier
- CONCLUSION
Trident Z RGB RAM isn't any cheaper.....RAM is dirt cheap at the moment, 2x8GB 3200mhz is under £70. It was more than double that last year.
