- 19 Oct 2008
Yes you can. BFV works fine on a 2080 at 1440P with pretty much max everything. Everything is game dependent. Far Cry 5 New Dawn without RT gets lower FPS with nearly max everything.You can't even play at 1080p with all details maxxed with some technologies enabled (RTX, anyone?).
Personally I dunno why folks would cheap out at 4K. At that res I'd want nothing less than a 2080 Ti (turning settings down IMO is a waste - you're paying £ for all that stuff in games). And for an optimised solution I'd not be using an old CPU either. Top end resolution, top end components IMO. Not long ago 4K monitors were what, upwards of £1k? Running it with a £50 or whatever 2500K processor just seems so wrong
.So while 4K might not push processors as hard as other resolutions, nobody has tested every single game out there and every single config. To ensure you're getting the best out of a top end resoltuion monitor I'd recommend a good modern fairly top end build generally
