AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
25 Oct 2013
Kent
Someone also said the same source had a 197 point single core.
https://www.reddit.com/r/Amd/comments/c4lpc8/new_r5_3600_scores/
6 Jun 2016
That Portuguese listing as per guru3d in case anyone missed it:
Ryzen 3000
Cores / Threads Frequencies Recommended retail price Euro
Ryzen 3 3200G
4/4 3.6 - 4.0 GHz $ 99 € 108.90
Ryzen 5 3400G 4/8 3.7 - 4.2 GHz $ 149 € 163.90
Ryzen 5 3600 6/12 3.6 - 4.2 GHz $ 199 € 218.90
Ryzen 5 3600X 6/12 3.8 - 4.4 GHz $ 249 € 273.90
Ryzen 7 3700X 8/16 3.6 - 4.5 GHz $ 329 € 361.90
Ryzen 7 3800X 8/16 3.9 - 4.5 GHz $ 399 € 438.90
Ryzen 9 3900X 12/24 3.8 - 4.6 GHz $ 499 € 548.90
The UK prices are listed at some re-sellers now (all prices inc. VAT)
AMD Ryzen 5 3400G @ £151.44
AMD Ryzen 5 3600 @ £198.95
AMD Ryzen 5 3600X @ £245.41
AMD Ryzen 7 3700X @ £320.90
AMD Ryzen 7 3800X @ £382.52
Man of Honour
Man of Honour
23 Dec 2002
London
Correct me if I'm wrong, but those look like fairly similar prices to the Intel equivalent.
All these months of hype, and there's that little difference in cost? Gotta laugh.
21 Sep 2008
The 3400G is just a slightly refreshed 2400G so not worth getting over the 2400g especially on how low they go for now.
Now im a bit stuck at knowing which way to go, if its true that the Ryzen 5 2600 is going to drop to to less than £100 do i get a the Ryzen 5 2600 and a cheap video card or just get the APU as planned.
Surely the Ryzen 5 2600 is going to be much more powerfull than the 2400g and with me being a none game player i dont need powerfull graphics
15 Apr 2010
If you don't game then I would go for the Ryzen 5 1600 which is likely to drop even further and pick up a discrete GPU like the GT 1030.
19 Apr 2003
Could you make use of the extra cores and more system memory (thinking of the future too)?
If so, 2600 and a discrete/passive GPU.
28 Sep 2018
The iGPU actually acts as a heat sync because it's a cold part of the silicon that the heat from the cores can leak into, removing it to replace it with another two hot cores will just increase the thermal density.
Then there's the added power consumption, taking the 9900K to 250 Watt's, add that to the increased thermal density and you have more of a problem.
I do think it's possible they can squeeze a bit more and even spread out a bit to reduce the thermal density. If you look at this die reference, you can see massive the igpu actually is. And while it can semi perform heat spread duties, it's not ideal due to its placement.
I still don't think there's an engineering commitment that's worth it for a low volume part even if they could.
11 Oct 2015
They seem to be a touch on the higher side was hoping the 3600x £229 and 3700x £279
