Someone also said the same source had a 197 point single core.
https://www.reddit.com/r/Amd/comments/c4lpc8/new_r5_3600_scores/
Will my Asrock B450m Pro need a Bios update to use the 3400G
Thats going to be a pain as its still sitting in its Box and i have no cpu to update it with.
That Portuguese listing as per guru3d in case anyone missed it:
Ryzen 3000 Cores / Threads Frequencies Recommended retail price Euro
Ryzen 3 3200G 4/4 3.6 - 4.0 GHz $ 99 € 108.90
Ryzen 5 3400G 4/8 3.7 - 4.2 GHz $ 149 € 163.90
Ryzen 5 3600 6/12 3.6 - 4.2 GHz $ 199 € 218.90
Ryzen 5 3600X 6/12 3.8 - 4.4 GHz $ 249 € 273.90
Ryzen 7 3700X 8/16 3.6 - 4.5 GHz $ 329 € 361.90
Ryzen 7 3800X 8/16 3.9 - 4.5 GHz $ 399 € 438.90
Ryzen 9 3900X 12/24 3.8 - 4.6 GHz $ 499 € 548.90
The UK prices are listed at some re-sellers now (all prices inc. VAT)
AMD Ryzen 5 3400G @ £151.44
AMD Ryzen 5 3600 @ £198.95
AMD Ryzen 5 3600X @ £245.41
AMD Ryzen 7 3700X @ £320.90
AMD Ryzen 7 3800X @ £382.52
Correct me if I'm wrong, but those look like fairly similar prices to the Intel equivalent.
All these months of hype, and there's that little difference in cost? Gotta laugh.
I thought the 3900X was the 9900K competitor?????
9900K is 440 - 500 notes.... big gap to the 3800x 3700x prices...
I don't know enough about AMD chips but if 1.308v a lot or no for that level of OC?
The 3400G is just a slightly refreshed 2400G so not worth getting over the 2400g especially on how low they go for now.
Now im a bit stuck at knowing which way to go, if its true that the Ryzen 5 2600 is going to drop to to less than £100 do i get a the Ryzen 5 2600 and a cheap video card or just get the APU as planned.
Surely the Ryzen 5 2600 is going to be much more powerfull than the 2400g and with me being a none game player i dont need powerfull graphics
Could you make use of the extra cores and more system memory (thinking of the future too)?Now im a bit stuck at knowing which way to go, if its true that the Ryzen 5 2600 is going to drop to to less than £100 do i get a the Ryzen 5 2600 and a cheap video card or just get the APU as planned.
The iGPU actually acts as a heat sync because it's a cold part of the silicon that the heat from the cores can leak into, removing it to replace it with another two hot cores will just increase the thermal density.
Then there's the added power consumption, taking the 9900K to 250 Watt's, add that to the increased thermal density and you have more of a problem.
