- 7 Nov 2017
I want.
Wonder if my Girlfriend will allow me to bump my budget up to 1.5K for my rebuild![]()
maybe you should ask her for your balls back too
I want.
maybe you should ask her for your balls back too![]()
2700X @ 4.3Ghz: 424
3600 @ 4.2Ghz: 480 (+13%)
Add 100Mhz (+2.5%)
Total IPC +15.5%
Interesting, I can get it in either Florida, New Jersey or North Carolina. I will do some research and wait for benchmarks.
What does her other boyfriend say?I want.
If legit, one is 500£ the other 200£. My 2700 only gets 418 @ 4.1GHz.
Got my eye on this one, but at $359 it's a lot of dough. Not sure if it's worth it.
@humbug @andy_mk3 by dust i ment. KLast time I was swapping gpu to that 1080ti Sea hawk EK edition there ware dust BALLS in the pc.... Now something went HDD most likely as it was not under any load just idling. Spark ignited dust and from that cables and went on. If he had not had METAL side panels it would have torched the freaking home.
It's not PSU or Coolant leak from what he sees fire started from HDD's basket.
one more shot. Spec was [email protected] 32gbs of ddrs 1080ti 3x2tb hdd +500 gig ssd. AAA and Superflower 1000w psu
Update is... Fireman said it looks like Fire started from Hard Drives Cage.
Would not post this here But over 20 year of building pcs i seen loads of hardware go BANG motherboards psus gpus cpus... NOTHING LIKE IT.
Temperatures ware all ok last time when i was around and monitored also nothing ever passed 60c....
FWIW i bought a molex to pcie adapter for my gtx1080 (from ebay). One day the pc just crashed anyttime it loaded a game so i had a look at the connector. It had burnt through the wires at the crimp, but unless you took it off you'd never tell. Still not sure how it happened.Had to replace an old (12+ year old?) seasonic m12 PSU that i was running in my current rig last week after it started throwing sparks around inside the case. Whilst try to keep all of the fans/coolers cleaned i had forgotten to check the cooling slots on the bottom of the case and these were clogged with large clumps of dust that the cooling fan on the PSU must have sucked in...
So bottom is stock with "sweet spot" RAM, not bad at all. Will be interesting to see what kind of overclocks people can get with this cheap-as-chips chip.Daily 3600 Geekbench update.
5939 SC
4.3GHz
3600MHz RAM
65ns Latency
X470
http://browser.geekbench.com/v4/cpu/13678723
5843 SC
4.2GHz
3600MHz RAM
66ns Latency
X470
http://browser.geekbench.com/v4/cpu/13678648
