Update: Turns out my example was a damaged one from all that mucking about in shipping to the UK as the backlight was showing through like a grid on the darkest scenes in HDR games like underwater in shadow of the tomb raider. Phillips were amazing and shipped me a brand new unit with the best backlight possible on a screen of this size -absolutely no backlight issues. It is a lot better than the first screen for desktop use too. This one has uniformity of 100% in all parts of the screen and only 99% in one top left corner - hits 997nits and 18000:1 contrast on the displayhdr windows store app too. This seems a lot better than any of the review units reviewed out there so to find pretty much a 'golden sample' of the Phillips is good as now it'll be better than the FALD tv and also have really high resale value if I ever upgrade to 144hz 4k next year. I believe they tested and calibrated this screen before sending.
Brilliant that you got such a good replacement!!
Sorry for late reply to this thread and your post, but I was thinking of getting one of these as a computer monitor. I wouldn't be using it for gaming at all. It's main use would be desktop stuff, web surfing, some photo and video editing(nothing remotely serious) and maybe a movie ever now and then.
I have been reading some reviews and some of them mention that it's not suitable for desktop use as it's too big and text doesn't look right because of the pixel layout.
Are those reviews right? My viewing distance will be between 2ft and 3ft away. Would you be able to sit at that distance from your screen and surf some webpages and see what it's like please? Also, if you can make any comments, good or bad, about using the screen as a desktop monitor only, it would really help my purchasing decision.
One more question, have you used the Multiview feature? And does it work from two inputs from the same GPU?
It's a choice between 2 decent 27 inch monitors or this.
